Co-deployment and Re-deployment of Generic Applications |
CoRDAGe is a co-deployment and re-deployment tool for grid
applications. It interfaces distributed applications with grid
middlewares in charge of node reservation and deployment to bring
dynamicity during the whole execution time. CoRDAGe is currently able
to (re)deploy the JuxMem
data sharing service using the OAR
reservation tool and
the ADAGE deployment
tool. Interactions between grid applications and CoRDAGe are made
thanks to the XML-RPC protocol
specification. A set of specific actions have to be written in C++
following the CoRDAGe framework, to provide support for your
applications.
CoRDAGe has two main goals: 1/ it translates high-level application-specific actions into low-level generic operations intended to interact with reservation and deployment tools and 2/ it performs smart preliminary planification driven by the application needs. |
CoRDAGe uses
a logical tree to represent the applications: it is designed to
express proximity between the entities and perform a
smart pre-planification of the deployment by selecting
appropriate resources. This model allows co-deployment of
several applications by merging their corresponding logical
representations. Logical representations are thereafter mapped onto
the physical resources representation, also built as a logical
tree.
The CoRDAGe prototype is now at test phase within
the LEGO project. You can
join the CoRDAGe project hosted at
the INRIA
forge. This tool relies on the following
XML-RPC implementation. You
need to install this library before compiling CoRDAGe. Please read
the INSTALL file for installation notes.
Reference paper:
Loïc Cudennec and Gabriel Antoniu and Luc Bougé, CoRDAGe: Towards Transparent Management of Interactions Between Applications and Resources, STHEC/ICS 2008, June, Island of Kos, Aegean Sea, Greece [paper, slides, bibtex] Contact: loic.cudennec(at)irisa.fr, cordage-discuss(at)lists.gforge.inria.fr |
This work has been
supported by Sun Microsystems, the Regional Council of Brittany and
the French National Agency for Research project LEGO
(ANR-05-CIGC-11). Experiments presented in this project were carried
out using the Grid'5000 experimental testbed, an initiative from the
French Ministry of Research through the ACI GRID incentive action,
INRIA, CNRS and RENATER and other contributing partners. The CoRDAGe
logo contains
some material
released under the Creative Commons Attribution 2.5 / GNU Free
Documentation License.
